2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-18T20:24:32+00:00
    Guys,
    I was able to alleviate 90% of my issues by forcing the newer Intel driver mentioned in this thread (20.19.15.4352). Just use 7zip and extract the files, and manually force it in device manager by saying (Let me pick from a list of device drivers on my computer).
    My original issue (and snippet of email) to Microsoft is as follows:
    "The SP4 is border-line unusable in it’s current state with the one that I have from early inventory. If you are connected to the dock and lock the PC, 75% chance it doesn’t come back and you have to hard reset. Put it to sleep and the odds are even worse. In that 25% of the time that it actually does come back from lock, you lose your external monitor configuration and the display driver crashes.
    In this state, I wouldn’t send these out to our end users. I can deal with this, but I know end-users would never be able to handle it. "
    Thanks for the Intel driver suggestion all; it really has mostly fixed my issues.
    Chris
    2016-01-20T21:13:48+00:00
    I too manually installed Intel display driver version 4352 and have yet to received another display driver crash notice or odd transitions in display brightness.  Microsoft might be delaying the official release of this driver until they can fully test it after they rushed out the previous build stating that it fixed all of the display issues and that turned out not to be the case for everyone.  The other possibility is that they've already determined that this build does not resolve all of the issues and are waiting for Intel to release the next build.  This and other driver updates might be included in Insider Preview Build 11099 (Info here).  As an IT Engineer, I might not mind installing Insider Preview Builds but wouldn't necessarily go recommending that others do the same because I have experienced some very annoying issues with certain builds on my other 2-in-1 convertible laptop and a tablet.  Here some SP4 issues that I'm experiencing.
    1. Yes it's a backlit display but I'm experiencing a higher than normal amount of light leakage from multiple spots around all sides that's more noticeable in low light situations.  Will see if display driver version 4352 affects that.
    2. Type cover:  Frequent key and trackpad response issues where the cursor location sometimes disappears and reappears in the wrong place as there's a delayed response to my typing or tapping on the trackpad.  Much less frequently, the fingerprint scanner fails to work after the system wakes from sleep.
    3. OS issues: Edge browser is a system resource hog and huge drain on the battery, especially when opening sites with multimedia content.  This causes the system fan to run at full speed.  Closing the culprit tab is sometimes difficult and the tab title will just flash at you.  Hitting the back arrow to exit the page before closing the tab tends to help.  Be sure to close Edge before entering sleep/hibernate mode.
