2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-14T10:33:24+00:00
    Maybe but on this page:
    http://answers.microsoft.com/en-us/surface/forum/surfpro4?tab=Threads
    There where 2 stickys that promised a fix for sleep in the beginning of 2016, written by microsoft. A few days ago they just dissapeared...
    2016-01-14T12:57:48+00:00
    It's because it will probably never be fixed. Do a search through the forum for the keywords below (in article) from the original sticky
    http://www.windowscentral.com/microsoft-working-sleep-issues-surface-pro-4
    And you probably won't find that article here anymore. Probably because it paints the picture that they knew about the problem prior to shipping the devices. Then again, I don't think anyone here is a real Microsoft person, so not sure if is legally applicable and could be used as a basis for a class action law suit.
    Microsoft marketed a "Mercedes" and the buyers in return got something much less.
