2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-14T09:30:37+00:00
    Microsoft,
    Is anyone reading this? It's been nearly 20 days since Intel released a new display driver and still no official update from you guys...??
    Everybody is still stuck with the BETA driver... Come on...
    Also why has the sticky explaining the sleep issue and promised fix in the beginning of 2016 been removed from this forum?
    Any news on that?
    Please be a little more forthcoming with news, progress, anything...
    2016-01-14T10:17:39+00:00
    Microsoft,
    Any news on that?
    It probably hasn't been removed, the moderators of this forum have a habit of combining literally anything remotely related. This means that colossal threads like this one are created that make it near impossible to find anything useful.
