2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-12T13:49:43+00:00
    I have Surface Pro 4, have installed all updates and keep getting the error message.  Took it back to BestBuy; Geek Squad service told me nothing was wrong.  Is there any place I can go for help....Geek Squad was no help at all.  12/2/15 download (I'm assuming I got it as my Windows Update says I'm up to date) didn't help my situation.
    I'm past the 30 days so I can't get a replacement device by walking into the shop , however I spoke to Microsoft and they confirmed that BestBuy (or whomever you bought it from) should have replaced it. They sounded annoyed that the shops say it's not their issue but it is definitely BestBuys issue in this case. They should swap it and do the right thing for the customer - maybe contact Microsoft if there is any doubt, or stand in the store and ring Microsoft directly before walking away and have the case number handy to quote - hand the phone over to discuss.
    I'm in the UK and certainly we have the right to simply return the product within 30 days if it's not fit for purpose....  The Sales of Goods Act. If it's crashing and the battery is no good this would be covered.
    Unfortunately I waited past the 30 days to do something about it so I'm going the Microsoft route and they're being very good with remote support etc (mainly for the bad battery) - But shortly I'm going to rub a refresh build to see if that fixes the battery and if not I'll get a replacement unit!
    Worth considering for anyone else!
    2016-01-13T09:11:22+00:00
    Im using surface pro 4 for a month. suddenly today while waking it up the display lost its brightness and said failed to start display drive. after restarting the device the brightness went up to highest and brightness button is not working. It does not even work if i fix it from the control panel.
    what should i do?
