2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-12T13:30:27+00:00
    Pawneejeff, Perhaps u should read my post and curb your misplaced sarcasm. My question was clearly addressed to superdoc99 based on the content of his post, not to you.
    Let me repeat.
    scopedoc99,
    Just to clarify, are u saying that the method u have used to do updates is Automatically and that u have never had to manually installed updates or drivers?
    2016-01-12T13:38:13+00:00
    I have Surface Pro 4, have installed all updates and keep getting the error message.  Took it back to BestBuy; Geek Squad service told me nothing was wrong.  Is there any place I can go for help....Geek Squad was no help at all.  12/2/15 download (I'm assuming I got it as my Windows Update says I'm up to date) didn't help my situation.
