2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-12T03:50:19+00:00
    scopedoc99,
    Just to clarify, are u saying that the method u have used to do updates is Automatically and that u have never had to manually installed updates or drivers?
    2016-01-12T12:55:39+00:00
    In brief...yes. silly me. I believe that 's what micro soft says to do.
