2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-12T00:22:03+00:00
    SP4 I7 16gb 512 SP has been on automatic update checked driver and it is .4352 "latest version" crashes Microsoft Movie manager every minute or two (particularly when performing editing functions), the one or two times I tried VSDC editor and occasionally with media player. haven't tried much other media- anyone have a video editor (the simpler the better) that seems to work? thanks in advance
    2016-01-12T00:32:07+00:00
    OK. After spending 2 hours following someone's instructions on Micr Winds chat site. I ended up uninstalling and re-installing a device driver that I already had (20.19.15.4326) which is the latest that Windows update routine offers. I'll bet that your solution to go to Intell directly for the xxxx.4352 version is what I'll have to do....or as you say,..wait till Micros gets around to putting it out. It will have to wait till tomorrow. There is just so much of this fun I can stand..
