2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-11T22:58:08+00:00
    I get regular crashes also - shows black screen when resuming from sleep. Requires holding reset button 30sec and rebooting.
    2016-01-11T23:22:10+00:00
    Either wait for Microsoft to release the next Intel Display driver update or if u are technically proficient download and install the latest version directly from Intel.com .  Instructions on installing the intel driver can be found in earlier postings on this thread. You should check that all updates are installed including the 1511 build 10586 Windows 10 update(to check run winver from dos prompt).
    I am using intel ver. 20.19.15.4352 and most of my display issues have been resolved including the blackscreen waking from Sleep.
