2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-11T22:26:23+00:00
    I am still getting this crash of the display driver. 1/11/2016. And I have done everything I can to make sure all updates have occurred.
    2016-01-11T22:52:33+00:00
    pawneejeff,
    What is  driver date and version of the display adapter?(get it from Device Manager)
    What is the version of windows 10 u have installed?  (get this at dos prompt type winver)
