2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-05T10:19:50+00:00
    I have my SP4 connected to a Samsung 4K 24:" monitor. Monitor @60 Hz.. Driver crashes every time (monitor blinks as if its puggled at that moment) when u use browsers or any videoplayback. All the latest drivers are ofcourse installed.
    2016-01-05T16:19:54+00:00
    Mine too.  Just updated the driver on 1/4/16.  Roads in Maps now showing up fine.  However, already had one screen lockup today on 1/5/16 after only 1 hour from clean boot by just browsing with only 3 tabs open in Edge.  Cortana responded to a verbal request but could not seen anything updated on the screen.  Then she did not respond again after that.  Had to do a hard reboot.  ugh...
