2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-05T02:38:35+00:00
    I also have been running the latest driver directly from Intel and so far no issues.
    2016-01-05T06:04:19+00:00
    Take a good look at the files available for download at the intel site...
    The Beta one is the SAME as Windows released: 15.40.12.4326
    Performance is BAD with this one. Using chrome and viewing youtube results in freeze/lockup and needs hard reset.
    Then there is the 15.40.14.4352 version. Released by intel after the Beta driver. Performance is GOOD with this one. I have been using it for a week and I have not had any crashes (some people still have crashes it seems..)
    But this one is "not made" for the Surface (as only microsoft sanctioned drivers via WU will install) so you have to use a trick to update your driver. See my previous posts on how to do this.
    We are waiting for microsoft to release this version as a tested driver via WU. As always they take there sweet time.
    The 15.40.10.4300 version was the driver version before the beta version, I do not know the performance of this driver.
    This is based on personal experience with my i7 Surface.
    Nope.
    Maybe it works for you, but I installed the exact version you are talking about. Installed it exactly as described. Crash fest. In fact, way less stable than what I have installed now "20.19.15.4326" which is currently the one that is installed via updating the driver through the 'find latest' option in the device manager.
    I have the i7 16gb 256ssd. And I can voucher for the win64_154014.4352 version running horribly on my Surface pro 4.
    Sorry to bust your bubble.
