2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-04T20:38:16+00:00
    I operate my Surface Pro 4 with 2 dell 23” touch screen monitors.  Repeatedly throughout the day I receive the following error message.  "Display driver stopped responding and has recovered.  Display driver Intel HD Graphics Drivers for Windows 8(R) stopped responding and has successfully recovered."  No data is lost but this occurs throughout my work day and it’s quite disruptive.
    2016-01-04T22:52:05+00:00
    Make sure you have all the latest updates.
    Microsoft released updated graphic drivers in December to fix "most" issues with the video hardware.
    But, issues remain and we all hope it will be fixed soon.
