2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-04T09:12:36+00:00
    Take a good look at the files available for download at the intel site...
    The Beta one is the SAME as Windows released: 15.40.12.4326
    Performance is BAD with this one. Using chrome and viewing youtube results in freeze/lockup and needs hard reset.
    Then there is the 15.40.14.4352 version. Released by intel after the Beta driver. Performance is GOOD with this one. I have been using it for a week and I have not had any crashes (some people still have crashes it seems..)
    But this one is "not made" for the Surface (as only microsoft sanctioned drivers via WU will install) so you have to use a trick to update your driver. See my previous posts on how to do this.
    We are waiting for microsoft to release this version as a tested driver via WU. As always they take there sweet time.
    The 15.40.10.4300 version was the driver version before the beta version, I do not know the performance of this driver.
    This is based on personal experience with my i7 Surface.
    2016-01-04T15:57:53+00:00
    I have had 15.40.14.4352 installed since 2 days after it's release and have had zero video adapter crashes on my sp4 i7 512 16.  Also have had no sleep hangs and the Maps app displays roads correctly.
