2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-03T18:17:46+00:00
    No updates have been released in for januari, you can check the update history here:
    https://www.microsoft.com/surface/en-us/support/install-update-activate/surface-pro-4-update-history?os=windows-10
    You can also check the driver version of your gpu in device manager to see if you received a GPU update.
    You probably still have the beta driver released on the 17 of December...
    2016-01-04T08:52:05+00:00
    These display driver crashes are much worse using the intel beta drivers. I get in crash loops with Youtube running under that beta driver. At least with the MS release, it only crashes once at a time :\
    MS, you OWE us all BIG TIME! This is insane.
