2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-02T15:29:05+00:00
    I was in the Edge browser with two tabs open. Can't remember the web pages but probably sports sites with heavy graphics/video.
    2016-01-03T18:09:54+00:00
    Good news, at least so far. I went to Best Buy and exchanged my SP4 for a new one and I can report that I have experienced none of the issues that I had with my previous SP4. Also, I received a bunch of updates - I can't tell if the early January update that was previously promised was delivered or if I just got the previous updates. Anyway - it's working now without problems so far. Fingers crossed.
