2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-29T20:11:40+00:00
    Man it seems like every day i find something else that is wrong with this device.  I am having issues with Bluetooth speakers now. The sound keeps going in an out. I took my sp4 in for the video issue and they stated that they are working on an updated driver. So i will give it another could of weeks then i am taking this thing back in. All this money i spent on it to have this many problems just sucks
    2015-12-30T12:08:22+00:00
    I have no idea whether it's hardware or software and there doesn't seem to be any clear answer. Most posts seem to indicate software. My problems are:
    1. crashy buggy video driver, even after installing the newest intel update
    2. Network won't recognize other computers consistently (had 3 hours of MS tech support for that, no luck)
    3. Homegroup doesn't work (MS tech support couldn't fix that)
    4. sleep awake problem many others have mentioned
    5. The $300 hub has two monitor ports but can't get two half decent monitors going with it. even following the the MS guidelines to have them both set at 30hz
     I see others have had these issues, and so I asked MS to extend my return period to give them a chance to fix it... My last possible return date is the 14 of Jan. There is no store nearby...
    If I return it, I doubt I will  replace for this "Rolls Royce" i7, SSD500GB, 16GB machine. I'll be looking at competitors on the Apple side and Windows side. Hope it doesn't come to that. what a disastrous Christmas Vacation. 40 hours of Beta testing for MS.
    If you really like the device/concept and don't need an almost-gaming level machine, my recommendation (before giving up) is try a return/replace for an i5 version. If it has problems, then give up. :)  This is anecdotal, but in reading through the message boards - the i7 is currently more troublesome than the i5. I had many problems with my i5 which I received on Day 1 of the product launch, and now have none (outside of the Surface Dock/PaperWeight, which is a whole other story MSFT needs to address).
