2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-28T01:36:52+00:00
    Hello GGCODE ,
    Sorry to hear you have some troubles with your Surface Pro 4. Please install all available updates then restart the device. Please ensure your Surface is fully charged before start using it.
    Let us know how it goes.
    Best regards,
    I bought a Surface Pro 4 last week and it was having multiple problems from the display driver stopping and recovering, to not recognizing my keyboard, making random chirping noises every 3-4 minutes, battery draining after fully charging within 3 hours and the display driver stopping and then recovering. I returned the product today to the Microsoft Store. They gave me another Pro 4. Well, this one is much better, but I have the same exact problems as GGCODE. The message: "Display driver stopped responding and has recovered" appeared the first time while installing initial updates and then two more times within 3 hours. The device has also frozen up 3 times where I have to force shut it down only to wait as the screen will not come back on....it remains black. This is sooo unacceptable since I just paid $1,200+ for this pc.  I have done all the updates (I have gone there multiple times). Now what? I spent several hours getting this pc set up with apps and programs only to now discover that I most likely have to return it to the store tomorrow (that is about 40 miles away). :-( What is up with this new product?
    2015-12-28T13:36:20+00:00
    Hello, How do you install the intel driver?
    I just get an error saying "
    This driver being installed in not validated for this computer"
    Setup will exit....
    Thanks all.
