2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-27T19:38:47+00:00
    Exactly the same story here.
    To Maceo3121:
    On the official update I got infrequent (say 10 to 15 a week) crashes/freezes/lookups and the occasional not waking from sleep.
    Now I have installed the new driver from Intel (which is not really tinkering as it made for this chipset, you just have to manually convince it to install as it detects it's a Surface and won't install generic drivers...) I had no (zero) problems.
    No more freezes or lookups and it always wakes from sleep.
    If Microsoft releases there versions of this driver (will probably be another week or so) I can roll back to the previous official driver, and install their new version via Windows update. So not really tinkering, just making the system usable until Microsoft releases their version. Which I think just has some hardcoded settings you could otherwise change with the Intel HD graphics app as this will not be installed with their version. If you install the generic driver it is installed and you can change a few settings that would not be good for battery live and so on...
    My system is also the i7 16gig 256gig SKU
    2015-12-27T21:34:22+00:00
    No tinkering for me. Just happens when external displays. Please don't assume people having issue have tinkered with their Surface Pro 4. Thanks.
