2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-27T17:41:27+00:00
    I hadn't tinkered with my machine either. It was the original OS that came with the machine plus Microsoft updates and firmware and hardware updates pushed by Microsoft. However I still had major problem with SP4 not waking from sleep when pressing the power button.
    As suggested by other users, forcing SP4 to hibernate instead of sleep is a workaround. When I saw the note from other users suggesting the new Intel drivers fix the problem, I decided to take the risk as I don't think it could get any worse - having to press the power button and then waiting for few seconds and not knowing whether it will eventually wake up or needs restarting is not the experience you expect from a tablet in 2015. Fortunately, this driver update has fixed that problem and SP4 reliably wakes up with every power button press and so far, I haven't had any display driver crashes.
    I hope Microsoft finishes testing this update and pushes the driver through Windows update soon.
    2015-12-27T18:24:58+00:00
    I have no idea what you guys have tinkered with or installed on your SP4 but I am having zero graphics crashes on my Surface since installing the official update issued few weeks back.
    It seems the ones who tinker with drivers which have still yet to be fully tested and issued by MS are the ones having the most problems....coincidence?
    I am going to wait until the official driver is issued via Windows update because MS will have tested it and probably also include the calibration settings specifically for the SP4 display.
    hmmm.... the only tinkering that has happened to this SP i7, 500GB, 16GB RAM computer is Microsoft Tech support.... 6 hours of it... and ZERO results, and when none of the MS support worked, I did a refresh of the entire system ...  I'm 30 hours into this with zero tinkering.  ...  the cost of my machine and dock is $3500 Canadian + 20 hours work + 10 hours of research ... + I had to buy a new Monitor, and still the dual external monitor dock doesn't work... I have never been more disappointed with a purchase in my life...
    This thread has 458 comments, and over 13,000 views... seems like I'm not the only one. This never should have been released like this. We are paying $1000's to be beta testers.
