2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-27T17:11:38+00:00
    Yes I have been following it.
    I do casual gaming and web surfing on my SP4 and not experienced any crashes for the last week or so.
    Intel has released new drivers just before Christmas and have no doubt that MS will test them and have them ready in the new year as a formal update.
    The only annoying problem I have is one of battery drain but all can be fixed once MS release updated firmware which I know they are working on.
    2015-12-27T17:27:35+00:00
    Well I'm glad to hear that you're having no issues - as stated before the issue is not occurring with all devices, just some of them.
    I have one of the i7, 256gb ssd, 16gb ram configurations.  I have all the available updates installed.  I tried installing the new drivers released on the 22 mentioned in other posts, but they won't install - I'm not messing with bypassing the installation and just using the files.  I have not 'tinkered' with any drivers and I am still experiencing a few different problems - the computer is freezing, graphics drivers crashing, web cam not initializing properly when first turning it on for facial recognition, and a few other things...  so no, it is not happening just because people are tinkering with drivers...
