2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-27T14:57:36+00:00
    Perhaps you haven't been following the thread - the reason people are tinkering with the drivers is because of the issues - if there weren't issues people wouldn't be tinkering with them.  So no it is not a coincidence....
    If you have followed it, and read previous posts, you would have noticed that it is an apparent problem with Skylake processers and intel graphics - I've even recently had issues with my 1 year old desktop (not running a Skylake processor) with intel graphics crashing - so no, it is not a coincidence...
    If you would have followed the posts, you would have also noticed that they admitted that it is only an issue with some of the devices, not all of them - mine must have been built on a Friday just before it was time to go home for the weekend.....
    Try watching a few videos - streaming amazon prime, Netflix, or even downloading a video file and playing it through Windows Media player, and browsing the web or doing other stuff at the same time - you should know relatively quickly if you have a problem or not.
    2015-12-27T15:30:47+00:00
    Normally I would agree, but on my last SP4 I didn't tinker AT ALL and I got crashes every once in a while. Not often, but it happened. Most of the time though it was the screen not turning on, even after being powered down. Now, with this SP4, I updated these drivers manually and I've been going strong for a few days now with 0 issues with extensive use while on vacation. :)
