2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-27T12:36:14+00:00
    Looks like I'm going to have to install that Intel driver and give it a spin.
    2015-12-27T14:13:13+00:00
    I have no idea what you guys have tinkered with or installed on your SP4 but I am having zero graphics crashes on my Surface since installing the official update issued few weeks back.
    It seems the ones who tinker with drivers which have still yet to be fully tested and issued by MS are the ones having the most problems....coincidence?
    I am going to wait until the official driver is issued via Windows update because MS will have tested it and probably also include the calibration settings specifically for the SP4 display.
