2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-26T18:46:56+00:00
    hello, I have just bought my surface and I am getting this msg continuously! is there any solution to this ? feels like I need to return to Ipad !! pls assist asap. thanks
    2015-12-26T19:49:43+00:00
    This a common problem for most of us Surface owners.  Ensure you have run all of the latest firmware and software updates.  I ran the 2 December updates and have suffered very few issues.  Of course, intel has released the updated drivers and most of us are just waiting for Microsoft to approve them and push us a stable set of video driver.
