2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-26T06:57:57+00:00
    Cool,
    i'm thinking about also installing it but I wonder what will happen then when microsoft releases their version. Will it just install over the manually installed version? Or will it not even show up as an update...
    2015-12-26T16:54:26+00:00
    Someone brought me as new surface pro 4 yesterday from John Lewis. I have received the display driver stopped and not responding message at least 5 times today while watching movies on amazon, which has ruined my experience because now tv shows and films will not show.
    I have reset it many times, closed my Microsoft edge and shut down the surface.
    Would anyone know what the problem could be?
