2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-26T03:34:26+00:00
    There seems to be a new driver (released yesterday by Intel) for the iris 540...
    https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-
    This is not yet pushed by Microsoft though... (holidays?)
    Anybody care to try? Using the .exe will not work (driver not appropriate for this system, go to manufacturer...) but using the .zip file and manually updating the driver via device manager should work.
    I'm thinking about trying it...
    KEY ISSUES FIXED:
       Display may flicker on 6th Generation Intel Core and related processors
       Corruption seen in Microsoft Store Maps application
       Stability Fixes for 6th Generation Intel Core and related processors w/ Intel® Iris™ Graphics 540
       System may hang on systems with both discrete graphics and Intel graphics
       System may hang on GfxBench
       System may hang on systems with HD Graphics 510
       Reduce probability of getting a blue screen in certain scenarios
    Just applied it and I can tell u that it does fix the Maps app missing road lines issue.
    2015-12-26T06:51:57+00:00
    I have been running it for 24 hours now and not once have I had the issue of it not waking up from sleep :)
