2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-25T20:01:26+00:00
    Intel have just released new version of their Skylake graphics driver (22nd Dec). I am pretty sure Microsoft will issue a new graphics driver/firmware for Surface based on this early in the year after internal testing.
    Intel claims the new driver resolves the following:
    KEY ISSUES FIXED:
    Display may flicker on 6th Generation Intel Core and related processors
    Corruption seen in Microsoft Store Maps application
    Stability Fixes for 6th Generation Intel Core and related processors w/ Intel® Iris™ Graphics 540
    System may hang on systems with both discrete graphics and Intel graphics
    System may hang on GfxBench
    System may hang on systems with HD Graphics 510
    Reduce probability of getting a blue screen in certain scenarios
    https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-
    2015-12-25T20:14:34+00:00
    This was posted on the previous page. But thank you for letting us know ☺. Now we have been discussing it Hehe.
