2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-25T17:03:20+00:00
    The surface get stuck constantly
    i updated it, reset it
    and still when ever i start working with one adobe app like photoshop or premier and want to watch a movie..
    its constantly get stuck or shutting down its display driver
    what can i do?
    rony
    2015-12-25T19:23:08+00:00
    I have been with most people on this board for some time "Why release a new hardware device with all these bugs", but recently we just received several test windows 10 laptops (Lenovo, Dell, Asus) and all three have the same screen flicker. video driver failure in edge, mouse stops and poor resume from hibernate as the surface books we have.
    Bottom line, seems not to be a new Surface issue but Windows 10 and Skylake chipsets.  We upgraded a few older machines and they do not replicate these errors.
    So maybe we need to duplicate this thread at Intel.
