2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-25T08:42:12+00:00
    That's good news, for clarity, you downloaded the .zip file and chose update driver in device manager and pointed it to the unzipped files?
    I wonder what will happen when Microsoft releases the update when the driver is installed it this way...
    Do you still have the black screen after a wake from sleep? That's something my device has sporadically...
    2015-12-25T08:53:37+00:00
    This is one of my biggest issues: But not from wake.... From having it turned OFF! Can you believe that? From having the device TURNED OFF I sometimes get the black screen and need to force the power button + volume down to reboot it...
    I just upgraded the drivers so let's see if that fixes anything.
