2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-24T09:51:38+00:00
    2015-12-24T16:44:06+00:00
    I have installed it and it seems to have fixed all issues I had, no crashes yet, no flickering and no dimming on dark backgrounds since changing the power setting in the intel control panel.
    I have the i5 128gb
