2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-22T23:41:56+00:00
    yep gotta agree, I was getting this crash about 5-6 times a day a month ago, a few weeks they released an update and am happy to say I haven't had one driver crash since!
    If people are still getting it, make sure you have the latest updates installed as the update has remarkably improved this issue (and as awesmdiver said, a perm fix is being worked on by MS and Intel and should be out early next year, I don't have the link but definitely remember reading this aswell )
    2015-12-23T01:44:19+00:00
    Have all drivers up to date, latest cumulative, and Windows Update is happy. Adapter driver still crashes occasionally, with MS Office 2016 of all things (many problems, will likely revert to Office 2013 if I can, though that is another story)  and with a multi-monitor configuration.  It is better, 3-4 times a week instead of each day. Happened to me today.
