2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-22T02:51:29+00:00
    Could you point us to a communication Microsoft admitting this? I've seen nothings so far except, hard restart and update, and reinstall windows.
    2015-12-22T03:30:34+00:00
    I had this at first (with Win 10, of course), but it's been a week or so since I've seen it now, so it appears that it was fixed in some recent update.  Nice when it actually works that way and bugs just go away.
