2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-21T19:27:08+00:00
    No I have not. That is horribly inconvenient and would tak a lot of time as it deletes programs. When I first got the device I brought it up and then I did a fresh install just to make sure that it was clean from the start. That was about a month ago.
    2015-12-21T22:42:33+00:00
    I have the same issue. My driver date is 11/20/2015. Is that the latest one?
    I also struggle with external monitor over the SP4 Dock. Quite often it is unable to connect to the display. If I disconnect the dock from the tablet, wait 10 seconds and reconnect then it often solves the issue.
    Windows is also confused about which monitor is the main monitor. It will say that my external monitor is the primary, but the SP monitor is acting as the primary showing the "Ask me anything" and clock, etc. I have to manually configure it to switch twice to make it work.
    I am skeptical that Microsoft has so many issues when they control both the hardware and the software. I have always loved Microsoft's ability to run on any hardware, now it seems like Windows is good on any hardware except MS hardware.
