2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-21T17:59:14+00:00
    Yeah, not sure about that.  I have a day one SP4 and basically I rarely see any issues now.  Granted I had to reset the computer to a fresh install, which isn't a big deal now days, and the only real issue I still have is the sleep issue.  Other than that, system runs fine with an occasional driver crash.
    2015-12-21T18:01:24+00:00
    By chance have you reset your system to a fresh install to see if that helps?
