2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-21T16:17:30+00:00
    I have no idea what is different about my SP4 or my wife's but I have not experienced the display driver crash in weeks and I don't think that my wife has ever experienced it. I'm doing regular stuff on it, Outlook, Word, Excel and I'm using the touch friendly versions of Cnet, Kindle, USA Today etc. I also play games like Tomb Raider, Batman Arkham City and have not had the crash.
    My challenge now is getting it so that my printer doesn't disappear. The drivers are loaded but it often can't find my printer. And forget that nothing prints from edge.
    2015-12-21T17:33:22+00:00
    I am on my third Surface Pro 4 and all of the issues have pretty much disappeared.  I do occasionally have the cursor stop working but that is solved by disconnecting and then reconnect the keyboard.  A quick and simple fix that only happens a couple times per week. One of the employees at the Microsoft store suggested that the problem could be caused by different "builds" of the computer and that may be.  The one I have now is different from the prior two and there are just no issues at the moment.  Display adaptor crashes have not occurred since the latest Dec update and Netflix also plays without issue.
