2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-20T20:58:28+00:00
    Have the same situation and waiting for the proper fix.  Just occasional failure.
    2015-12-21T14:53:23+00:00
    None of the updates have fixed the crash that I receive every few minutes... Only a hard reset will clear the issues, then it crashes again within 20 minutes. Microsoft customer service has been horrible. Please, let's get this resolved already.
