2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-20T19:58:05+00:00
    Ugh - Here we go again. I think I am done with this thing. I hope my Best Buy return policy is still good. I've had it and have waited too long. This is just ridiculous.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3ea90dbe-4612-49ec-b2e2-944da0b12cf6)
    2015-12-20T20:28:51+00:00
    Yep, issue affects all Skylake processors ATM.  MS already said working on resolution for early next year.  For now, driver crashes and far and few and since it really doesn't affect anything, I'm good there.  Have SP4 going into Hibernate and that works fine for now.  Overall, still like the product but yes, would be nice when these issues finally get resolved.
