2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-20T09:08:01+00:00
    2015-12-20T09:08:07+00:00
    True about the crash reports (hopefully) - but I also should have added that seeing who else has the same problems might help us. For example, I would say that anecdotally, after reading through this thread and some others - it is the i7's predominantly still having the Display issues. See the last few posts here (all i7):
    http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfdrivers/surface-pro-4-noticeable-backlight-flicker/9913f2d3-295f-4a38-93f4-892c84df8b57?page=5
    Agree on battery life - it's tolerable, especially for web browsing. Seems to depend on the use, though. If my son is gaming, the battery life is about 2/3 what he gets on his iPad playing the same games. For the money we paid, and it being Microsoft, I would expect more honest marketing. We would have bought it anyway, and not felt intentionally deceived - which WILL affect our propensity to consider MSFT products in the future.
