2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-19T21:15:43+00:00
    Well, don't feel so bad now guys.  I have been lucky on my SP4 that I haven't seen a display driver crash for awhile.  Not to say the issue is resolved, because it's not.
    However, with build 11082 on my desktop, now NVidia graphic drivers are crashing.  First time for this.  What fun.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=6eb33c87-6f82-43c2-be8d-8f54d477d879)
    2015-12-19T21:51:39+00:00
    Sorry to hear that awesmdriver.
    That makes it sound like more of a problem with Windows 10 (which they are trying to push on everyone) than the surface pro hardware/drivers.
    It looks like certain NVidia cards have been having problems as well, even on new computers - look at the comments: http://www.drivethelife.com/windows-drivers/how-to-fix-display-driver-stopped-responding-and-has-recovered-on-windows-10-8-7-xp-vista.html
    I also noticed people complaining about the Surface Pro sleeping issue - it was draining the battery.  I find it interesting that all the responses I've seen from MS about these issues isolate it to the Surface.  However, I have a higher end HP laptop that's about 2 years old now, which has worked perfectly.  However, when I installed Windows 10, I started experiencing problems with it going to sleep - it would shut off the screen, but the fan and stuff would still be on like it was still running.  The best solution I seen at the time was to remove the battery pack to kill it, lol.  And here I bought a new Surface Pro 4, hoping that I wouldn't have any issues......what was I thinking.....http://h30434.www3.hp.com/t5/Notebook-Operating-System-and-Recovery/Sleep-and-Shutdown-issues-after-upgrading-to-Windows-10/td-p/5177663
    These things make it sound like the problem lies with Windows 10.  Somehow MS is doing a good job at making all these issues sound like isolated issues with devices, not Windows 10.
