2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-19T06:43:43+00:00
    Thanks for the response, and I agree.  However, the OS is supposed to be collecting the crash reports and sending it to MS - so they should have thousands of reports about this crash from all of us.  To me, as a MBA grad, that would provide me with a hint that they have a serious ongoing problem with the product, which should demand an immediate investigation and solution by their team.
    I will add that my specific device configuration wasn't released until 12/4/2015 (the i7, 16gb, with 256 gb ssd).  I ordered it on 12/5/2015 only because I have never seen this issue listed in any of the reviews, so I really didn't look into it.  The device arrived on 12/9/2015, and I am using the standard $130 surface pro 4 keyboard, the stock charger, and a usb 3.0 hub, with no other accessories being utilized/connected at the time I was experiencing the issues with streaming Amazon Prime movies.
    While the battery life isn't as they promised, to be honest I am relatively happy with it (although it would be nice if it did last longer) - for being such a ultra small, yet extremely powerful portable computer, 5-7 hrs of normal use isn't too bad.
  2. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2015-12-19T11:08:04+00:00
    Don't know what you mean by "win 8 on SP4" as the SP4 ships with Windows 10. However, EVERYONE is/was experiencing the display driver stopped responding issue. New video driver from Intel is needed.
    Make sure you have installed all available Windows Updates, including the TH2 1511 OS update.
