2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-19T06:15:47+00:00
    I have a surface pro 4, i7, 16gb, 256 gb hdd configuration.  I have all the available updates installed, yet I am still experiencing display driver issues, which is not just limited to scrolling situations on web pages.  I am using IE 11, not edge, and I have experienced it several times while streaming Amazon Prime videos, along with several "funky" short vertical lines showing up at the bottom of the video.  Also, while the video is streaming and I open up the Action Center, the display in the entire area of the action center is fuzzy.  I have also had the driver crash several other times, while not even using internet explorer.
    I have expected some issues with new hardware releases, but I am upset that this issue has not been fixed yet. Especially after spending well over $2000 on this computer and accessories specifically for this device - If I would have known about this issue I would not have made the purchase.  I will be advising people to purchase a different product, or wait until this issue is resolved.
    2015-12-19T06:24:19+00:00
    It's odd that people are such different experiences with the SP4. I use Edge every day, and have not had a Display Driver crash since the 12/2 updates. I think it might be useful MSFT if everyone reporting problems here states the configuration of their system.
         The only serious bugs I have experienced since 12/2 are with the Dock (Brick) - and possibly a minor issue with battery life (about 7 hours max).  My configuration:
    SP4 bought 10/26 in U.S., 8/256 i5, Type Cover with Fingerprint Sensor
