2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-10T15:21:44+00:00
    I thought so too, but the flickering happens in Netflix.  I also got an BSOD and a display crash after the update.
    2015-12-11T20:55:13+00:00
    Thank you for your open and candid responses. Right now, our team is working hard to address your feedback as soon as possible and we’ll communicate on this thread whenever an applicable update is available. We also now have a sticky thread here on the main Surface forum page that we’ll refresh when applicable updates are available. Thanks again for your feedback!
