2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-08T23:56:51+00:00
    I just installed today's update and then went the Edge.  Everything was moving along way faster than normal and I was thinking "wow this is great."  Then for the first time in a week Edge just started a constant flicker and then the screen went blank.  The Edge browser then came back up and started flickering like mad. I finally had to reboot.  I did not get any of the normal display driver error messages.
    2015-12-10T05:46:48+00:00
    Same issue here.  After some reboots the flicker is not as often now.  However I get blue screens 1 or 2/day and I often have to do two finger hard reboots.  Still needs work.
