2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-08T12:05:40+00:00
    i installed it but yesterday it crashed .
    2015-12-08T13:20:37+00:00
    I have the HD 4600 in my Lenovo, and I'm currently using v. 20.19.15.4326. I'm not using Edge though. Prior to installing the update, I would get the display driver error when using Chrome and Outlook (which really boggled me), and that started happening after the Threshold 2 update.
