2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-08T05:02:58+00:00
    The display adapter crash wasn't specific to the SP4 - it affected many different devices. I got the same thing after the November update on my Lenovo laptop. I fixed that by going with the Intel beta driver and since then I haven't add an issue on the Lenovo, or the SP4 since the December update.
    2015-12-08T05:22:17+00:00
    What processor/graphics do you have in your Lenovo? Which driver version are you running? I installed the beta driver (v. 20.19.15.4326) and am still getting frequent driver crashes when using Microsoft Edge. Its not exclusive to Edge either, it has also has crashed when using Skype. I really like my HP but this graphics driver issue is maddening.
