2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-05T00:34:21+00:00
    Not really. The issue is unrelated to the graphics drivers (Which is what was updated 12/2/15) Although recently I have had occasions where I've put the device to sleep and have gotten <1%/hr of battery drain. That's like a 460 mWh. That's new. But then the very next time it slept it was drained ~6%/hr or ~6500 mWh. Very no bueno. Seems tres random.
    2015-12-05T06:10:27+00:00
    Has anyone seen any improvements since the 12/2/15 update?
    I have not had any video display popups since the 12/2/15 update.
