2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-04T18:19:01+00:00
    I have not seen what i'm about to mention commented on anywhere so please excuse me if it is old news. I have the SAME "Driver crashed/recovered" problems on my SP3 but more interestingly...I have the same thing on my Windows Mobile 10 devices (L920, L830, L640) This cannot be an issue specific to the SP3/4 video card as all the phones I own do the same thing...all day long.  Anyone else seeing this?
    btw, this problem didn't start until 10586.11 (both sp3 and phones). They were both ok until 10586.11
    2015-12-04T18:23:32+00:00
    I had the same thing happen on my Lenovo laptop once 10586.11 came along. I fixed it by using the beta driver from Intel.
