2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-04T17:42:18+00:00
    Same boat, last update rocked for me.  Almost zero issues.  Loving my SP4 a lot these days!  Just needs a little battery life improvement and this thing will rock the casbah!
    2015-12-04T17:51:01+00:00
    " Use it for a week; I don't have to charge it, 'cause when I close it I'm saving every bit of battery life with no drain. It's phenomenal work by the Surface Engineers."
    • Panos Panay, Microsoft Surface Book Event Keynote. October 6, 2015
    https://www.youtube.com/watch?v=W7wN8DAPh80&feature=youtu.be&t=1h24m43s
    Slight contradiction?? Or was one supposed to infer that hibernate should be used? Or was Panos using hibernate? Or is he lying.
    Yes, I'm using hibernate for now - there really is no alternative.
