2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-04T17:34:47+00:00
    "hibernate would destroy my SSD in a few months", um no it would not.  The Surface Pro 4 contains a Samsung PM951 SSD which has a 1.5 million MTBF rating.  So, unless you plan on keeping your Surface for a 100+ years I would say, Hibernate it and don't worry about it.
    2015-12-04T17:36:23+00:00
    I have been telling people on this thread multiple times about Connected Standby and to Hibernate their systems until the issue is resolved.
    I have NO issues with battery drain while hibernated and of course the system will not turn on and stay on.
