2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-12-04T13:53:30+00:00
    I had a major update on my Surface Book overnight but I am still experiencing frequent display issues...very frustrating!
    2015-12-04T15:41:23+00:00
    I installed the new driver update and video driver crashes and black screens upon wake do seem to be reduced but not eliminated.  I got a black screen yesterday twice (I know the driver is not supposed to fix this issue) and one crash.
