2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-03T21:37:31+00:00
    Even after the November Hardware update released yesterday which included updated intel graphics driver, Edge is still having this issue when playing embedded video.
    2015-11-03T22:14:30+00:00
    It seems the November Firmware update fixed the screen flickering issue...  so far I have no seen it occur again.
    However, the graphics driver has crashed again after the update.  I got the "**Display driver stopped responding and has recovered"**notification, and interestingly it still said "Display driver Intel HD Graphics Driver for Windows 8".  It would be nice if Intel/Microsoft could actually make a driver for Windows 10 that works.  I really hope they release a new graphics driver soon to stop these crashes.  Otherwise I might return my Surface Pro 4.  For this kind of money I shouldn't have to deal with these nagging issues.  I can't believe Microsoft would ship a product with such a bad driver from the factory.
